? about Texas speed True duals
Old Mar 25, 2006 | 04:11 PM
1nastyss's Avatar
Default ? about Texas speed True duals
I have the tsp td's, do any of u guys have problems with the driver side almost touching the fuel lines, if so, how did u fix the problem, can i cover the fuel lines in Dynamat and maybe wrap that side of the exhaust in header wrap....Please help, thanx guys
Old Mar 25, 2006 | 04:44 PM
TheBlurLS1's Avatar
That's what she said...
You can flip the fuel line brackets upside down, and put the fuel lines back in. Raises them about 1.5"
Unless you're talking about the spot about 18" from the header collector where it goes under the body brace. Then you just have to tweak the pipes a bit. They have a heat shield right there, so you can run the pipe pretty close before you have to worry.
