is fuel injector cleaning recommended
Old Jul 18, 2002 | 04:31 AM
WS-6 BILL's Avatar
Default is fuel injector cleaning recommended
I'm running 91 octane chevron. dealer says injectors should be cleaned at 15,000 miles.Is this correct? also fuel filter at 12,000 miles
when should i change the transmission fluid on an A4? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jul 18, 2002 | 05:52 AM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
Default Re: is fuel injector cleaning recommended
You mean pull the injectors and clean them? Couldn't hurt but sounds like they want to pick up some extra $$. I've never had mine cleaned at 55K miles, just add the cleaner to the gas occasionally.
Fuel filter change sounds good.
I like to change my trans fluid about every 15K miles, first change in that range for sure.
Old Jul 18, 2002 | 06:19 AM
BYE RICE's Avatar
There's a product called "BG".It's a three part process.One you pour into the gas tank.Another goes into the fuel rail schrader under pressure.A third is fogged down the intake through the throttle body.Most places charge in the $ 140 range for the service.It not only cleans out the injectors,it also cleans the top of the engine.I just had this performed & I'm going to autotap the car & see if the knock retard issue is fixed.
Old Sep 6, 2002 | 10:30 PM
CamaroCain's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by BYE RICE:
<strong>There's a product called "BG".It's a three part process.One you pour into the gas tank.Another goes into the fuel rail schrader under pressure.A third is fogged down the intake through the throttle body.Most places charge in the $ 140 range for the service.It not only cleans out the injectors,it also cleans the top of the engine.I just had this performed & I'm going to autotap the car & see if the knock retard issue is fixed.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">We do this all the time at the dealership i work at on 5.3, 4.8, and 5.7 cars and trucks. but we use a product by WYNN's instead of BG. works real well. there is actually a campaign out on the 4.8, 5.3, 6.0 liter trucks that come in with random misfire codes to have the injectors cleaned. by the way i think our dealership charges $120 for this.
Old Sep 7, 2002 | 08:30 PM
SixPak's Avatar
the wynns product works quite well. I have personally used it in the past with good results when the fuel systems were suspect in drivability issues. might be a good idea as a preventive maintenance item if you get a lot of crappy gas where you live. or worse yet, water fouling everything up, like in the winter.
Old Sep 7, 2002 | 09:02 PM
BB's Avatar
BB
Where can you get this wynns stuff?
Old Sep 8, 2002 | 02:16 PM
SixPak's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by FlamnTA:
<strong>Where can you get this wynns stuff?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I only ever used it when I worked in a garage turning a wrench for a living. a sales rep from wynns came by every couple weeks or so and kept us supplied. so I guess all I can say is check some of the garages in your area and see if they can help you out.
by the way, this ain't some stuff you just dump in your gas tank. you need some tools, adapters and such, to tie into your fuel system. you shut your fuel pump off and run your car off the wynns product. sometimes it'll take two or three cans of the stuff to get the job done. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
I haven't looked, but they may be on the internet.
<img border="0" alt="[Corvette]" title="" src="graemlins/corvette.gif" />
