Electrical Problem: Any Suggestions?
Old Jul 21, 2002 | 07:21 AM
phil46y's Avatar
Default Electrical Problem: Any Suggestions?
A few weeks ago I put a nitrous setup on my car, NX wet kit. Yesterday I bought a new switch panel for it, and this morning I set about wiring the new switch panel and a new bottle opener in. I disconnected the battery, and ran all my wiring and got everything connected.
Satisfied I had everything wired correctly, I connected the battery and began checking switch functions. They all seemed to be working correctly, so (without bottle hooked up or engine running) I left the ignition key in the run position and made contact with the WOT switch to check that both the fuel and nitrous solenoids were working correctly. One loud click and that's it folks.
Now when I turn the key to the run position I can hear the fuel pump, and the radio will come on. It will not crank, and there's no power to the dash gauges. I have checked every fuse under the hood and on the end of the dash with a meter for continuity and they all check good. I also changed out the ignition relay thinking it may have fried, but that wasn't it. I have also disconnected the battery for about 30 minutes to reset any memory, still no luck.
Everything other than the ignition is working, headlights, turnsignals. radio, etc. I'm now almost certain it may be an inline fuse somewhere under the dash, anyone know where one may be located?
Any further suggestions?? Maybe a link to a wiring schematic?
Old Jul 21, 2002 | 08:47 AM
Sears's Avatar
!Dial-up Director
Default Re: Electrical Problem: Any Suggestions?
Moving to Nitrous section, maybe someone has had the same problem...
https://ls1tech.com/ubb/ultimatebb.p...c;f=4;t=001257
Justin
