misfire at idle
Old Jul 22, 2002 | 08:04 PM
bctruck's Avatar
Default misfire at idle
When the motor is warm, it will some times misfire and drop the #7 cyl. I replaced the plug and wire and had the injectors flow balance checked. I think it's the coil? I don't have the equipment to take with me, doesn't do it all the time. Have you had coil problems? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Idles about 600 in gear. raising the screw under the TB stop doesn't help the idle at a stop just increases the speed at a roll.
