egr block off plate
Old Mar 27, 2006 | 09:05 PM
00transamnh's Avatar
Default egr block off plate
Hey, (did a search)
You guys that made your own egr blockoff plates; what did you use?
thanks
Old Mar 27, 2006 | 09:51 PM
lgobraves's Avatar
on the header i just cut off the pipe and welded it closed. On the manifold I used a 1 3/8 freeze plug
Old Mar 27, 2006 | 10:51 PM
do i need to worry about losing/cracking/chipping/ruining my ceramic coating if i weld the hole?
Old Mar 28, 2006 | 11:07 AM
to the top
Old Mar 28, 2006 | 12:09 PM
lgobraves's Avatar
no no no....Take off the egr. Cut the pipe close to where it bolts together with the header. Weld that opening closed there. So your not actually welding the header.
