INJECTOR SIZING, WHAT ARE YOU GUYS USING?
Old Jul 29, 2002 | 11:32 AM
Gene's Avatar
Default INJECTOR SIZING, WHAT ARE YOU GUYS USING?
not satisfied with the svo 30lb injectors, car seems sluggish. tuned with maft. numbers are ltft-0/1, o2-895-900. everything looks good but car is not up to its potential. At what point do 99 cars need injectors?
Old Jul 29, 2002 | 03:32 PM
Ragtop 99's Avatar
Default Re: INJECTOR SIZING, WHAT ARE YOU GUYS USING?
Unless you have extra cubes, a dry shot, or a SII heads with a very high revving cam, a '99 should be fine on stock injectors. I switched to 30lb SVOs because I shift at 6800 and wanted an extra margin of safety.
Old Jul 30, 2002 | 12:23 AM
Gene's Avatar
I initally did the svo's becouse of the dry shot. but off the bottle performance sufferd. now i tuned the crap out of it with a tech2 scanner and a maft. lt fuel trims are 1,0 and o2's are 895-900 wot. what gives this car on motor should go low 12's, it wont! on spray its fairly good at 11.66 but I still feel somethings not right.
