Anyone have any gains on "porting the primaries" of macs?
Old Aug 3, 2002 | 02:08 AM
swtvictory's Avatar
Default Anyone have any gains on "porting the primaries" of macs?
I am about to do a head install sometime this month and want to port my primaries in the meantime while the heads are off.
Anyone have any results?
Old Aug 3, 2002 | 02:38 AM
Onyx LS1's Avatar
Default Re: Anyone have any gains on "porting the primaries" of macs?
definitely will only help. probably not much, but its worth doing if you have the headers off and you have a dremel tool. doesn't take much time at all.
Old Aug 3, 2002 | 09:46 AM
AlonzoVersion 1.0's Avatar
It will help you out a little bit,Its not hard to do but its worth the extra time and effort.
Old Aug 3, 2002 | 10:07 AM
DrkPhx's Avatar
I ported mine. I'm sure gains were minimal, if any. Look at porting as not adding HP, but maximing the flow to prevent losses.I believe the exhaust port on the head is 1-3/4".MAC advertises these as 1-3/4" headers (inside measurement).My set had a 1/8" weld bead going around the inside most of the primaries. That amounts to a 1-1/2" inside primary when measured.
Old Aug 4, 2002 | 06:31 PM
swtvictory's Avatar
ttt
Any dynos.
