Pulley removal Q's........
Old Aug 4, 2002 | 11:46 AM
SPANKY LS1's Avatar
Default Pulley removal Q's........
I am removing the pulley on my 2000 A4 today, what specail tools will I need? I have a air compressor and impact already, anything else? Will I need some kind of special puller? Thanks, Shawn
Old Aug 4, 2002 | 02:05 PM
DravenMyers's Avatar
Default Re: Pulley removal Q's........
You'll need a 3 jaw puller. I got mine at Sears. You will also need a pry bar or something similar to lock the flywheel and keep the pulley from turning. Hope this helps.
Old Aug 4, 2002 | 03:09 PM
Chris Johnson 00 T/A's Avatar
!rope mod also works in the #1 cylinder if you don't have someone who can hold the flywheel for you.
You can also rent the tool at your local hi/lo or other parts store. Most of the time for free.
