Opinions/Recommendations for a Drive Shaft Safety Loop....
Old Aug 5, 2002 | 08:12 AM
FEAR THE LS1's Avatar
Default Opinions/Recommendations for a Drive Shaft Safety Loop....
Who is using what? I know the job a drive shaft loop is pretty straight forward, but how was the installation? Any problems with certain brands with clearance? Are the ones that bolt around the drive shaft instead of slip on just as good? etc etc
Thanks,
Lee
Old Aug 5, 2002 | 08:41 AM
DARK AGE 53's Avatar
Default Re: Opinions/Recommendations for a Drive Shaft Safety Loop....
Lee, SLP has a good heavy duty loop, the loop is quite easy too install. When installing the loop it's easier too remove the u-joint bolts (rear) if the wheels are off the ground (jack stands) and the tranny is in neutral, just rotate the wheels to get to the four bolts. If I can be of any help let me know, good luck with the mod.
Al
Old Aug 5, 2002 | 09:23 AM
WILWAXU's Avatar
Hands down! The new Lakewood #18022 Loop fits like a glove! Fits in existing bolt holes.. no drilling.
Moving to drivetrain.
