Oil filter clearence problem
Old Aug 5, 2002 | 11:53 PM
NataSS Inc's Avatar
Default Oil filter clearence problem
I have had my FLP's on the car for about a month now and when I put them on I noticed that the clearence between them and the oil filter was a bit to close for comfort. I would say about a 1/2 inch. Is this normal or do I need to look into a remote filtering sytem? I could really use the help on this one guys, I actually loose sleep thinking that the filter will fail due to the high temps from the headers.
Old Aug 6, 2002 | 07:34 AM
Fireball's Avatar
Default Re: Oil filter clearence problem
my dynatechs are the same way and I HATE it..I took some heat wrap and put them around the closest primary and held it in place with a hose clamp...needless to say I picked up 5psi of hot oil pressure <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Old Aug 6, 2002 | 05:11 PM
NataSS Inc's Avatar
anyone else running into this problem?
Old Aug 6, 2002 | 05:29 PM
12secSS's Avatar
Mt Hookers are about an inch away from my oil filter, HTH.
Old Aug 7, 2002 | 11:29 AM
NataSS Inc's Avatar
Has anyone tried using a remote oiling system on the LS1 yet?
