are swaping out 01 injectors worth it for me?
Old Aug 9, 2002 | 10:14 AM
gator's 99TA's Avatar
Default are swaping out 01 injectors worth it for me?
i am going to put in an LS6 intake and have LS1edit access so are swaping out my 99 injectors worth doing? i might plan on spraying the car latter in the year, but that is still in the air. could i make more power with edit with these bigger injectors (barely bigger).
just wanted your opinions. TIA!
Old Aug 9, 2002 | 01:12 PM
BLUEBYU's Avatar
Default Re: are swaping out 01 injectors worth it for me?
I am going through the same decision right now also....have the intake on it's way. I have decided to install the SVO 30 # . Two reasons....obviously good time to do it with the intake swap and I am currently running 80% duty NA and up to 96% duty on the gas. That is just with a 75 dry shot <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> I am definitely glad I have the means to check this **** out with ATap. BTW, got them through Mark at Raging MS for an excellent price of $280. I obviously recommend you go ahead and do the upgrade....but why '01...I believe they are only 28#. Not a big enough bump for me.
Later, Gator
Track Fri.?????
Old Aug 9, 2002 | 02:13 PM
cool info. i am thinking of putting them on since they are free - they are coming with teh intake i am buying.
Old Aug 9, 2002 | 02:38 PM
Ragtop 99's Avatar
If they are free, go for it. Don't expect more HP but if you add a dry shot they'll be useful. They should support going into the low 400s HP at the rear wheels, 100 shot plus bolt-ons.
Old Aug 10, 2002 | 02:13 PM
ttt
