Header install on a shop lift...help!
Old Aug 9, 2002 | 11:44 AM
INSSANE's Avatar
Default Header install on a shop lift...help!
I'm gonna install my 1 3/4 Grott headers on a shop lift, my question is, how do you do it?? How do you do the bolts from the top? I'm using the lift because it's safe and because I need to get the car HIGH to install these.
Thanks
Nick
Old Aug 9, 2002 | 02:33 PM
LT1FUN's Avatar
Default Re: Header install on a shop lift...help!
I recently helped some friends install some Hooker LTs on their '02 SS using a lift. You should be able to unbolt the old manifolds on the ground and then raise the lift and pull them out. Then, while the car is in the air, slide the new headers up in there. Kind of "wedge" them up in there and lower the lift and bolt them up. Not a bad job if you have a lift and air tools. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Good luck!
Old Aug 10, 2002 | 12:00 AM
AlonzoVersion 1.0's Avatar
Its pretty simple I would just unbolt them while the car is on the ground and then install them with the car on the lift.The lift doesnt have to be that high I would have it low enough to where I could install my bolts from the top.
Old Aug 10, 2002 | 12:04 AM
INSSANE's Avatar
So, take EVERYTHING apart on the ground, lift it up enough to fit the headers under, and bolt it up? Sounds good, I just have trouble imagining if the car is up 3 feet, me being 5'7 being able to reach.
Nick
Old Aug 10, 2002 | 12:12 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by INSSANE:
<strong>So, take EVERYTHING apart on the ground, lift it up enough to fit the headers under, and bolt it up? Sounds good, I just have trouble imagining if the car is up 3 feet, me being 5'7 being able to reach.
Nick</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes a lift is only good when you can actually use it bro.
