50lb injectors and stock fuel system?
Old Aug 12, 2002 | 09:26 PM
CoopDog's Avatar
Default 50lb injectors and stock fuel system?
I am doing an ARE 360 with a T-Trim and the 2.75 pulley. I was recommended to go with 50lb injectors by Nick. I have a Vortech T-Rex inline pump, with an otherwise stock fuel system. Will the 50's work ok with that combination? I understand programming is needed, I will dyno tune. I just want to make sure the hardware will be ok.
Old Aug 13, 2002 | 05:07 PM
WILWAXU's Avatar
Default Re: 50lb injectors and stock fuel system?
Nick didn't recommend the RaceTronics Pump setup?
Old Aug 13, 2002 | 05:23 PM
CoopDog's Avatar
No, he didn't say anything about that. I have a 99, as I understand they haven't released it for the plastic tanks yet. The racetronix setup looks good though. I am also concerned with the lines and rails. Will they flow enough to support 15Lbs. of boost?
Old Aug 13, 2002 | 06:58 PM
WILWAXU's Avatar
From what I've read... Nick can modify for setup to work with the 98 kit.
