Spark Plug Question
Old Apr 3, 2006 | 07:12 AM
1313of1600's Avatar
Default Spark Plug Question
OK, I just bought this car in Feb. and went to change the plugs over the weekend and got the drivers side done but i could not figure out how to get to the pass. side ones ?? Anyone have a way to get to them? What do i have to do pull the header? TYIA
Jonathan
Old Apr 3, 2006 | 09:19 AM
mvonada's Avatar
There is a special socket you can get, it slides over the spark plug, then you use an end wrench to take it out. Do a search, forgot where I got mine.
Old Apr 3, 2006 | 09:54 AM
CLOKWRK's Avatar
I was able to get to the rear pass. side one from underneath...still a PITA.
Old Apr 3, 2006 | 02:27 PM
Go Faster's Avatar
Here's the link you need!
http://www.installuniversity.com/
Old Apr 3, 2006 | 03:00 PM
rgaynor85's Avatar
i got the first 3 from up top just slip my arm in there and reached my other arm in from the front and had patients, the rear plug gotto do from underneath. i used regular sockets with a swivel thing and i was good
Old Apr 3, 2006 | 03:33 PM
MTN_Z's Avatar
I just removed the coil pack assembly and used a swivel adaptor. You can handle the last one from the top with a little patience. You have a 99 so you should remove the EGR tube off the manifold so you have a little more leverage. Just be careful not to drop the gasket or the bolts of the flange. F bodies are not very forgiving when it comes to helping you find stuff you dropped. I'm sure my neighbors were like "wtf" when they heard me getting all pissed...
