People with fuel sumps
Old Aug 13, 2002 | 08:38 PM
GateKeeper's Avatar
Default People with fuel sumps
What did you use to cut into the tank. A friend said a plasma cutter, but i don't know... something about sparks and fuel vapors <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> I would imagine if you use a cutting wheel, you would need to really clean out the tank good, huh?Also how did you go about making baffles...cutting three square holes? Something like this (taken off the web) http://rx7r1.deadpig.org/fuelsump-install.htm
<small>[ August 13, 2002, 08:41 PM: Message edited by: GateKeeper ]</small>
Old Aug 13, 2002 | 11:55 PM
y2khawk's Avatar
Default Re: People with fuel sumps
2 1/2" hole saw works wonders. Clean the tank out real good before you install it.
http://www.harlan-engineering.com/fuelsystem/
Old Aug 14, 2002 | 09:50 AM
Reckless's Avatar
Super Moderator
I did the same as Harlan did. Used a small hole saw, made several holes, removed the interior plastic baffle, and then had the sump welded over the holes. The remaining metal will keep fuel from leaving the sump, and the holes will allow fuel into the sump.
The hard part is finding a good welder that will weld a used tank <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Aug 14, 2002 | 07:23 PM
GateKeeper's Avatar
Thanks fellas. How much does a new 98 tank run?
