air pump
Old Aug 14, 2002 | 05:12 PM
muscratmauler's Avatar
Default air pump
does the smog pump go into the cats?
Is it better to just remove it all together when doing headers, high flow cats?
Old Aug 14, 2002 | 05:48 PM
NastySSoo's Avatar
Default Re: air pump
It does not go into the cats. You can remove it as I did. I did not even throw a code, but had it deleted when I had Ed W. do my tuning.
Old Aug 14, 2002 | 07:45 PM
I assume it goes in the manifolds then
Old Aug 14, 2002 | 08:49 PM
Sears's Avatar
!Dial-up Director
That is correct, on each header there is a flange for the AIR tubes.
Justin
