exhaust leak with dynatechs
Old Aug 18, 2002 | 05:19 AM
NX†C's Avatar
Default exhaust leak with dynatechs
alright so after putting them on and with their trick high flow merge collectors, i sealed up the primiaries and collectors with copper rtv gasket maker. now after getting on it a bit im hearing a continous ticking at low rpms til about 30mph til the drone overpowers it. is this alright to do, i was told it would seal them up, but now i may have to weld them up.
also if you do have dynatechs and welded the collectors to the primaries, how was this done as the muffler guy didnt see any way to get all the way around each primary for a good weld. thanks for any input.
Old Aug 18, 2002 | 09:45 PM
99WhiteSS's Avatar
Default Re: exhaust leak with dynatechs
Contact FLP (www.flpexhaust.com) about the weld-on collectors made specifically for the Dynatechs.
Old Aug 18, 2002 | 09:52 PM
WeatherGuy's Avatar
Get the weld-on collectors. Fixed all of my issues with one shot. You can call Dynatech directly to get them.
No real power difference with them either - pulled 491/490 RWHP/RWTQ with the leaky slip-on collectors, and 495/489 RWHP/RWTQ with the weld-ons. Measurements are similar enough to be within dyno noise level.
Old Aug 18, 2002 | 10:02 PM
JS's Avatar
JS
Yep mine tick too.
Its annoying...
I'm going back to Ported Macs with a custom Y
They made more power too...
JS
<small>[ August 19, 2002, 07:06 AM: Message edited by: JS ]</small>
Old Aug 19, 2002 | 02:43 AM
NX†C's Avatar
i have collectors part # 80-01515C which are the high flow merge collector 1 7/8" to 3".....just guess i'll redo the RTV and see how it turns out.
Old Aug 19, 2002 | 09:48 PM
BADZ's Avatar
Moderator
The merge collectors leak as I was told to stay away from them as the weld on's are just as good but alot cheaper and they dont leak....
