True dual mounting quest. needed ansa ASAP!!
Checkout my sig for my complete TSP TD install writeup!!
No but seriously,
I wrote up my whole install and took pics if your interested, its in my sig.
It may help answer any questions you have.
I think the vibrations come mostly from the resonance of the exhaust on the ground and backup on the body than anything else.
Hell that's whats' setting off car alarms, heheh
As far as rubber washers, keep in mind that the bolt going through the hole in your set wells is vibrating agains the hole itself so a rubber washer won't dampen that vibration any.
It will a little from the ends that are securing the bolt, but not the actual shaft of the bolt inside the hole, know what I mean.
Rubber washers prob help, but I wouldn't spend a whole lot of time, money and effort to get them on there.
just my op.
DJ
