ls1 or ls6 intake?
Old Apr 6, 2006 | 12:31 AM
Sunset'01Z's Avatar
Default ls1 or ls6 intake?
how can i tell the difference between an ls1 intake and an ls6 intake? my car was sold to me as an 01 but it was built in late 2000 and im worried i might not have the ls6 intake because i have egr equipment. Is there any way to tell which intake i have without pulling it off?
Old Apr 6, 2006 | 12:33 AM
just-a-z's Avatar
look at the floor runner. It should be flat if it is an LS6. You can tell without removing it from the car
Old Apr 6, 2006 | 12:34 AM
Sunset'01Z's Avatar
which one is the floor runner?
Old Apr 6, 2006 | 12:37 AM
Ws6man2000's Avatar
From: Ft lewis,Ft sill and thats all i hope.Katy texas
its underneath the intake the ls1 has a velly the ls6 is flat go to ls1howto.com and it will explain the differences and have pics as well
just-a-z's Avatar
The bottom of the intake. Look at the bottom of it, between the valley cover and your intake
Old Apr 6, 2006 | 12:38 AM
just-a-z's Avatar
http://www.ls1howto.com/howto/geniii...//IMAGE009.jpg
LS6 right
LS1 Left
Old Apr 6, 2006 | 12:46 AM
Sunset'01Z's Avatar
but u gotta take it off the car to see that.. im still confused lol
Old Apr 6, 2006 | 12:51 AM
just-a-z's Avatar
Go to your car. Stand straight in front of it and bend down as if you are looking right behind the Throttle body.
You should be able to see if the floor of your intake is flat or not from that point of view
 Michael S. Palmer
Old Apr 6, 2006 | 12:57 AM
FrozenMonkey's Avatar
LS1 has EGR crap right after the TB. LS6 doesn't....correct?
Old Apr 6, 2006 | 12:59 AM
Sunset'01Z's Avatar
its flat thanks SO MUCH!
well i think i have egr equipment. i can see a plate coming off of my exhaust manifolds with a line running off of it going to this ufo looking thing. thats egr stuff right?
Old Apr 6, 2006 | 01:25 AM
Cool Z's Avatar
Nope, that is for the A.I.R. system. It is used to speed up catalytic converter light off.
Old Apr 6, 2006 | 02:11 AM
TheBlurLS1's Avatar
That's what she said...
EGR has a line running off of ONLY the passenger side manifold to a valve bolted to the passenger side head, to a hole in the intake manifold behind the throttle body.
The similar looking tubes that run from each side, to the pump behind the driver side foglight. That loud *** air blower sound you hear when you start the car up is the AIR pump kicking on. It's use is what Cool Z posted.
Old Apr 6, 2006 | 12:18 PM
WILWAXU's Avatar
All 2001 model year & up cars have the LS6 intake.
Old Apr 6, 2006 | 12:19 PM
SMSFRC99's Avatar
why dont you just get the part number of off the intake and and run a search on it?
Old Apr 6, 2006 | 12:37 PM
Sunset'01Z's Avatar
dude, did u not read my post? the car was built late 2000 and i saw what i thought was egr equipment which 2001 up cars did not have. why else would i be questioning whether the dealership sold it to me as a 2001 when it could have been a 2000 with different equipment?
Old Apr 6, 2006 | 12:51 PM
WILWAXU's Avatar
Built date has nothing to do with it. Check your VIN:
http://www.chevy-camaro.com/chevy-ca...fourth-gen.asp
Old Apr 8, 2006 | 06:49 AM
VA2001SS's Avatar
#12561184 is the LS6 intake part number for 01-02. It is easy to see, it is centered middle of driver side.
