Question regarding condensation coming out of tail pipes
Any insight?
Just an FYI- my mods are stage 1 heads, 218/224 comp cam, regular boltons along with flp long tubes and slp loudmouth.
You should not, however, continue to see steam/condensation after the car is warmed up. Steaming out the exhaust after the car is warmed up could indicate other problems, like a blown head gasket or warped head.
Mine was steaming from leaking coolant into all 8 cylinders from both heads being warped .004". (Chris Johnson also just went through something similar).
Best of luck,
Bad30th
