HotCam w/ LS6 intake?
Mods, Ported MAF ends, 4000 Stall, 3.73 gears etc etc basically same stuff u have on ur car... i popped the intake (LS1) on the bottle when it backfired so I have put on a LS6 w/ Ported TB... new time soon to come i hope.
U can be in the 12.7-8 range no problem if u work on ur 60ft times, just getting some ET Street should get u there...
-Jim
<small>[ August 26, 2002, 10:52 PM: Message edited by: key master ]</small>
Josh
You might want to look at some supension mods, skinnies up front and spend some time tuning it all in ... took me about 30 passes to get my set up all dialed in ... I'm consistantly in the low to mid 1.7s on stock internals and mild converter - even on an unprepped track.
Yeah, the intake will help you. But, traction is really holding you back ... with that converter, proper suspension and your HP, you should be capable of low 1.6s.
