What short belt for ASP pulleys?
Old Sep 4, 2002 | 10:10 AM
Big Mike's Avatar
Default What short belt for ASP pulleys?
I've never run the short belt before and want to try it out. I have the ASP crank and alternator pulleys. What short belt do I need. Also, I heard something about grinding a bolt down or something to prevent from tearing the belt??? Can someone elaborate on this?
TIA!
Old Sep 4, 2002 | 04:28 PM
WILWAXU's Avatar
Default Re: What short belt for ASP pulleys?
ttt
Old Sep 4, 2002 | 06:00 PM
mike c.'s Avatar
the short belt i used is a 51'belt part #522k6 i use the crank only. you with the altonator pully too may use a 52' or 53'belt. the bolt you remove is the altonator bolt,dont grind the bolt or you may never get it off if you need to replace the thing. with pully and belt i gained 3.5 tenth, i only use the short belt at track or $$$$STREET RACING. goodluck to ya.
Old Sep 4, 2002 | 06:07 PM
Big Mike's Avatar
Thank you guys!
Old Sep 4, 2002 | 08:32 PM
JS's Avatar
JS
The bolt your talking about needs to be ground down,Its the lower alt bolt.I just ground it til it cleared the belt but still left enough material to put the bolt in and take it out if needed.
Otherwise u will shred the belt quickly
Big I got rid of the short belt mod on my car,It blows and IMO its not nadda on a stout car like yours.
JS
