Could use some help installing some gauges please
Where do you hook up the coolant gauge? He unplugged the sensor on the driver side head but the stock gauge was still registering temp. Is this the sensor he needs to tap into? If not, then which one?
The other question, is where is a good location to get an oil pressure sensor reading? Where should he hook up sending unit or is there someplace he can piggy back off of?
Thanks.
https://ls1tech.com/ubb/ultimatebb.p...c;f=1;t=007275
Not sure where to tap in for coolant temp. When I accidentally left the sensor in the head unplugged, it registered -32* and the fans ran all the time.
