Dynomax Powercat NJ emissions problem "not ready"
Old Apr 11, 2006 | 09:56 PM
Sunset01's Avatar
Default Dynomax Powercat NJ emissions problem "not ready"
I have a pair of the powercats on my car - the dynomax cat that looks like a small cherry bomb muffler with no heat shield. I failed inspection today and was told "you have straight pipes". Anybody think there is anyway past this? It didn't help that I got a 'not ready' for catalytic converters, but somehow I got a pass for 'overall readiness' ... ? I have ls1edit and all the codes related to rear 02s are set to 'Set SES- Yes' and 'Type X- turned off'. I see people with HP tuners talking about 'No error reported'. Anyone have any ideas what went wrong and how I can get past this visual problem ? Might I have to have rear O2s installed, the codes restored and some heat shields ?????
Old Apr 11, 2006 | 10:30 PM
2K2WS6TA's Avatar
For the cats, a recipt showing that they are indeed cats would probably get you past that problem if they ask why they were replaced, telling them they were clogged would be a good answer
As for the SES and error reporting you might want to post that in the pcm and tuning section (the tuner gurus usually hang out there)
Old Apr 11, 2006 | 11:31 PM
Sunset01's Avatar
Thanks. I think I got the catalytic "not ready" problem solved. I didn't realize PO420 and PO430 are also to be deleted in edit.
This still leaves me with a failure basically for 'emmissions control Systems Inspection' failure ... ug.
Old Apr 11, 2006 | 11:46 PM
2K2WS6TA's Avatar
Find the cats on the net, and take the page to the station and show them it's a cat (I'm assuming it's 50 state legal replacement) if so it should have a CARB EO # on it somewhere(or a sticker with that info on it)
Old Apr 11, 2006 | 11:52 PM
Redneck Z's Avatar
There are NO 50 state legal cats other than stock.
Old Apr 12, 2006 | 12:37 AM
98TADRIVER's Avatar
have a friend weld a heat shield on it, and take it thru again!!
