Anyone know how to get rid of a rattle from the headers
Old Sep 14, 2002 | 11:53 AM
99RamAirTA's Avatar
Default Anyone know how to get rid of a rattle from the headers
I installed a set of mac headers with a orp and the y pipe rests right on the crossmember. This seems to cause a annoying rattle at 1600 rpms or so. Does anyone have a cure for this. Any info would be greatly aprecieated <img border="0" alt="[Banging Head]" title="" src="graemlins/gr_banghead.gif" />
Old Sep 15, 2002 | 12:32 AM
sited12's Avatar
Default Re: Anyone know how to get rid of a rattle from the headers
I had the same problem when i put my loudmouth on. I just needed to really tighten up all the clamps for it and it went away.
Old Sep 15, 2002 | 10:12 AM
wrencher's Avatar
wrencher
Bend or cut as needed. "Slight modifications may be necassary" <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Sep 16, 2002 | 08:50 PM
CAlley2001's Avatar
I had the same problem but I had the Spohn Torque Arm and that uses a different crossmember. I just stuck a piece of heater hose in between the y-pipe and the crossmember. Problem solved!
Old Sep 16, 2002 | 09:09 PM
DARK AGE 53's Avatar
By "crossmember" do you mean the the tunnel brace, if that's the problem just get four longer metric bolts from AutoZone and use some flat washers to lower the brace.
Al
