Help on removing LS6 manifold
Old Apr 21, 2006 | 08:45 PM
SSmokin99's Avatar
I have a question. When I order the coolant lines and plugs and install the LS6 manifold will the SES light come on and if it does will that effect my cars performance in any way?
Old Apr 21, 2006 | 08:48 PM
Jake the SSnake's Avatar
The coolant plugs just re-route the coolant this will not set any codes.If you delete the egr system then you will set the ses light but this will not affect performance and it can be tuned out.
Old Apr 21, 2006 | 08:53 PM
SSmokin99's Avatar
I want to install it ASAP and if it doesn't hurt performance if the light comes on then I'll install it soon without deleting the code because that would cost money I'm sure...So I can install it today with no problems and drive around with the code light still on right?
Old Apr 21, 2006 | 09:12 PM
brad8266's Avatar
No the code doesnt hurt anything its just annoying and if you have a real issue you wont know it cause the SES is already on.
