What Pound injectors does my 2001 SS have???
Old Sep 16, 2002 | 04:31 PM
Damian's Avatar
LSX Mechanic
Default Re: What Pound injectors does my 2001 SS have???
You have 28's.
You only have to worry about big injectors if you're spraying a big dry shot. Wet kits do not max out injectors while spraying. If you're spraying wet, your pump will be the thing to worry about.
2001's have the bigger pump(like the 98's), so you should be ok spraying a 100 shot on top of the new cam. Anything bigger and i would keep a CLOSE eye on a-tap for lean conditions and fuel pressure...
Josh
Old Sep 17, 2002 | 12:23 AM
Billiumss's Avatar
Default What Pound injectors does my 2001 SS have???
This coming winter, I am planning on doing a cam install and while I'm at it, I want to buy and install bigger injectors.
I am currently running a 75 shot of juice and want to spray about a 125 shot on top of my new cam.
I think my car either has 26 or 28 lb injectors and I am thinking of buying 32 lb injectors.
Any tip's or idea's apreaciated....
Bill
