new coil pack brackets...confused..HELP
But what actually holds down the coils?
I see where the actual brackets get bolted down...but the holes in the bracket that I would assume hold the coils down....are not threaded.
Do I have to get a nut and a bolt for each hole? how is it set up originally?
That is the only way I can see that would work without a threaded hole.
thanks, Troy
Where did you get the brackets from? How much were they? Do you have a part number for them? I'll be needing some in a few months.
What about a very coarse thread...basically a self tapping thread?
would that work? seems like it would...and would be easy
As for the part number it is 12563288
Thought I would let you guys know in case someone didnt have the means or didnt feel like tapping all the threads. This is an easier and faster alternative.
that is all
that is all
