got harlan's 2step on the 98 tonight.
Old Sep 16, 2002 | 11:51 PM
MIGHTYMOUSE's Avatar
Default got harlan's 2step on the 98 tonight.
98 manual that is.. dunno if anybody has sucessfully installed one on a 98, but i havent seen it posted yet.
i skipped the relay part since i dont run nitrous/alky.. just put the arm led between a +12v and the yellow wire.
the arm button went betweeen the white wire and ground
*button is momentary, doesnt click.. is only on when pressed, then off when released*
the clutch switch.. i still think i can use the factory switch (there are 2 down there) but i got confused being upside down and bakward in the car and just wired in a micro switch and zip-tied to the start switch bracket. this switch goes between the grey wire and ground and is grounded when the clutch is out and breaks the ground when the clutch is in.
the box is located behind my pcm back in a little hole there completely out of the way and hidden, wired go through the firewall behind the pcm in the big grommet down there.
i have a crappy vid of it in action if anyone wants to host it please email me.. 1.2M mpeg.
i still need that turbo though.. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
