Need help ASAP identifying some injectors!
Old Sep 18, 2002 | 01:57 PM
Reckless's Avatar
Super Moderator
Default Need help ASAP identifying some injectors!
I traded for some injectors that are supposed to be 1998 LS1 Injectors. I called and talked with Milo at Pace Performance. He said 1998 LS1 injectors would be stamped with "12533952" which is the part number for that year.
Milo also said that not all LS1 injectors are stamped with their respective part number. He said some of the numbers are just internal stampings used by the plant.
Here are the numbers stamped on them:
12554271 on one side
0 280 155 752 on the other side
Neither of these numbers were found when searched for on the AC Delco site. Any help would be appreciated.
Old Sep 18, 2002 | 11:52 PM
99 TA's Avatar
Default Re: Need help ASAP identifying some injectors!
Hey Todd here's what I found.
LS1 Bosch 12554271 grey plastic injectors -- 25.2 lb/hr
Here is a Fuel injector database .
I couldn't find the Bosch numeber in the database though. I hope it helps a little. I have $20 for ya when I see you at Norwalk.
Adam
<small>[ September 18, 2002, 11:54 PM: Message edited by: 99 TA ]</small>
