Borla or True duals?
I use the term real loosely. Technically bullets are real mufflers. However, they don't do very much to actually muffle the sound. Change the sound, yes, lower the volume....not so much.
If you don't want a lot of noise you will probably want high flow cats and a non bullet muffler. Maganaflow makes some that I would pick for that setup....4x9's perhaps?? I forget...
heres what im doing tho
im ordering a TSP true dual system (what type of mufflers should i get? sweethunder, bullets, or moroso spiral flows) from texas-performance and im gettin pacesetter ceramic coated headers..
anybody against that?
also for the headers, i still want to be able to run O2 sensors.. should i just get O2 sensor extensions from TP?
I have Pacesetter's with the TSP Sweet Thunder muffler/resonator/whateveryoucallthem's and they sound incredible.....
Here a video to give you a good idea....
http://www.ls1sounds.com/true_duals/...am_mnc2886.mpg
Wait until you can do both at once, and make do with a cutout on your stock exhaust in the meantime. That's how I would do it.
