NEED HELP FAST>>>PLEASE!!!
Old Sep 22, 2002 | 10:11 PM
Satan's Angel's Avatar
Default NEED HELP FAST>>>PLEASE!!!
I posted this in diagnostic and tuning also...because the problem is drving me insane and i supposed to go the track on tuesday. OK...while driving once in while my temp gauge will completely quit working...when this happens it only quits fo a for few seconds at a time. But it almost shuts the car off when the gauge quits...it makes the car load up also. as you can imagine...this a a real nuiscance. I am getting a p0118...high voltage temp sensor circuit...any help or suggestions will be greatly appreciated!!!
Old Sep 23, 2002 | 12:10 AM
Dope's Avatar
Default Re: NEED HELP FAST>>>PLEASE!!!
Replace the sender and see if it goes away.
Dope
Old Sep 23, 2002 | 08:02 AM
z28fiend's Avatar
Satan's Angel,
I have had the same exact problem recently. It happened after I installed a 160 therm.. I didn't drain the coolant completely while replacing the thermostat, so when I hooked the hose back up, that intoduced an air pocket into the system. So, when I started my car up, the gauge would rise until it hit normal temp. then it would fall to zero. I called everyone under the sun about the problem. I finally contacted to Mark Schikel from SLP Engineering. He told me that I had air in the system and that I needed to apply a small amount of vacuum to my throttle body coolant line. So I did and it spit and sputtered for a while then ran smooth with coolant. Fixed my problem completetly. I never threw a code though, that was weird? Anyhow, good luck on your problem, it doesn't sound like air would be the problem, you'll find it.
