emissions part question
Old Apr 16, 2006 | 12:58 PM
dgformula2k's Avatar
Default emissions part question
Does anyone here know what part this is circled? Its connected to the fuel line, I tried to move it a little and it broke off (its plastic), now the SES light is on. I tried to superglue it together and then electrical tape over it but the light comes back on. Its some emissions valve I know, but what's it called? Any idea on the cost of replacing it? The area thats broke is the little tube part on the bottom right side, its hard to see because I put electrical tape over it. I can't believe glueing or taping it won't fix it. I might not have tape over the bottom half which is impossible to get a finger on. Is there a way to take off the whole unit and repair it that way?
Any knowledge about emissions would be great at this point, TIA.
Old Apr 16, 2006 | 03:15 PM
ashade98's Avatar
That's your EVAP solenoid! Got to autozone and check which code you're getting.
Old Apr 17, 2006 | 07:59 AM
Do you know if that part is replacable, or will I need to buy the whole unit?
Old Apr 17, 2006 | 05:19 PM
ashade98's Avatar
Not sure, there are guys running without it though. Do a search... it'll give you an idea if you want to run that way.
Old Apr 17, 2006 | 08:39 PM
WILWAXU's Avatar
https://ls1tech.com/forums/generation-iii-external-engine/442430-evap-pcv-guys-inside-please.html
https://ls1tech.com/forums/generation-iii-external-engine/438829-can-i-delete-evap-system-yes-no.html
