adj fan mod problems
Old Sep 25, 2002 | 03:00 PM
Ike's Avatar
Ike
Default adj fan mod problems
Having problems with my adj fan switch. It seems that there's a breaking point in which the switch is either off or on. The fan's only want to turn on at a certain point on the switch, whether the car is hot or cold. If I don't have it at the point, it feels like the fans aren't coming on. This I don't know for sure, but the car feels hotter. I don't have ATap to check the actual temp, either. I wired the switch just like the instructions from GTOJudge and installuniversity. The one question I had was pertaining to wiring the relay to the underside of the second fuse panel. I ran some wire to it, put one of those round push pins on it, and pushed it into the underside where the ETC. fuse goes, then put in a 10amp fuse. Is this how it's done? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> I suppose it must be wired correctly as it works.......... just not properly, it seems. <img border="0" alt="[Banging Head]" title="" src="graemlins/gr_banghead.gif" /> Maybe I'll just run it without the relay. I know that it'll run for a few minutes after the car is shut off, but I don't think that's a bad thing.
Old Sep 30, 2002 | 04:53 PM
WILWAXU's Avatar
Default Re: adj fan mod problems
ttt
