fuel pump for fuel module??
Old Sep 29, 2002 | 01:13 PM
1dirtyZ's Avatar
Default fuel pump for fuel module??
i just bought a walbro 255 fule pump and tried installing it but i couldn't. it seems the fule pump was made for a fule sending unit type of assembly, and i seem to have a fule module ( the one where the pump is in a plastic bucket kinda housing).
it looks totaly different from the pictures on the instructions, and the actuall stock pump is larger in diameter than the walbro.
is there a different kinde of aftermarket fule pump i could use?? where should i look for it?
<small>[ September 30, 2002, 09:29 PM: Message edited by: WILWAXU ]</small>
Old Sep 30, 2002 | 02:02 PM
MIGHTYMOUSE's Avatar
Default Re: fuel pump for fuel module??
the 255 install is not a drop in thing, sorry if someone told you it was.
remove the white bracket and old pump together.. and then use some STAINLESS hose clamps and rubber fuel injection rated hose to connect the new pumps, and rewire the leads accordingly.
Old Sep 30, 2002 | 08:46 PM
1dirtyZ's Avatar
thanks man, i thought so.
i took the old pump out and fanagled with the housing and i think i have it done. all i have to do now is to solder and shrink wrap the connector and i hope i'm done!!
Old Sep 30, 2002 | 09:31 PM
WILWAXU's Avatar
fixed the title for you <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Oct 1, 2002 | 01:47 AM
1dirtyZ's Avatar
thanks, it sounds better now!
i didn't know what to put in there. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
