Wiring up an Aeromotive inline pump
Is there a good place in the rear of the car to get a consistant 12volts all the time?
<small>[ October 01, 2002, 09:33 PM: Message edited by: DarkHorse_LS1 ]</small>
Since my battery is in the rear, it wasn't a problem to get the constant 12v from the battery to feed the switched side of the relay/fuel pump (Aeromotive A1000).
If your battery is still in the front, you can run a fused 10ga. wire from the front all the way back to the relay/pump.
