How to keep Mufflex Y from banging?
Old Oct 4, 2002 | 11:18 PM
quickWS6's Avatar
Default How to keep Mufflex Y from banging?
I don't want to do a torque strap, tried it, tore my strap...What else can I do? Don't wanna bend the floorpan up if I can help it. Maybe I can loosen up the y-pipe and bend it down? Anybody else have this problem with Hookers?
Old Oct 5, 2002 | 08:20 AM
99MONGOOSE's Avatar
Default Re: How to keep Mufflex Y from banging?
First install a 1LE trans mount. That will HELP the trans and motor from moving around. Did you notice I said HELP, not stop! This will sound a bit geto but it works very well. Go to your local autoparts store and buy a section of 2 inch heater hose, header wrap, several 3.5 inch worm-style radiator clamps (depends on how many places the pipe is hitting, as to how many you'll need), and some thread locker. My local store didn't have bulk hose so I just picked a pre-formed hose(the straightest one I could find. I ended up with a piece that looked like a "L" about 22 inches long). Get your self some header wrap. Find the area(s) where your y-pipe is making contact. Wrap that section of the pipe with the wrap. Install one clamp to keep the wrap secure. Put just a bit a thread locker on the clamp so it doesn't work loose. Now cut a 3 inch section of hose and unscrew a clamp, and then insert the clamp through the hose. Wedge the hose and clamp assembly between the pipe and chassis; bringing the ends of the clamps around the y-pipe, and begin tightening the clamp together. Basically the clamp will be as though you left it like you bought it and slid the y-pipe through it(like the y-pipe is a radiator hose. Configure the piece of hose untop of the header wrap and between the chassis and tighten as much as possible. Then use a little thread locker. I used a dremel to cut off the excess band clamp. The hose will now act as a cushion or buffer and your ears won't hear that "BANG" and more importantly you knock sensors won't detect it and reduce timing.
Old Oct 5, 2002 | 09:50 AM
TERRY's Avatar
THE header wrap is one of the best things i've done, and also i've dropped the cross brace and added several washers ...... NO MORE BANGING!!!! Just love it.............
