Ok, about to install my Hooker LT's
Old Oct 9, 2002 | 05:34 PM
bo0oost's Avatar
Default Ok, about to install my Hooker LT's
Hey guys..
Ok, I'm about ready now to install my Hooker LT headers on my 2000 Z28.
I have:
Headers
o2 simms
o2 extensions
EGR pipe from 98-99 LS1
AIR tubes from 98-99 LS1
Am I missing anything?
What can I expect during the install?
Any words of advice?
Thanks!
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Oct 9, 2002 | 06:16 PM
FstBlkz28's Avatar
Default Re: Ok, about to install my Hooker LT's
you do have a ypipe right? Other than that looks like you got the big stuff, better pic up a tube of anti seize for the bolts that hold the headers on. Other than that, i think you've got it all.
Old Oct 9, 2002 | 06:38 PM
11 Bravo's Avatar
Make sure you have a small 1/4 inch ratchet for the header bolts, especially the dreaded rear passenger bolt. Wear a long sleeve shirt unless you want the coil packs to shread your arm when tackling that bolt. Have something to cut the thin aluminum fuel line sheild. The front drivers O2 sensor won't clear it unless you cut a small piece away. I just cut a small "flap" so it still protects the fuel line. You have the EGR mod, right? Also, it helps to have an air wrench to remove the rusted bolts that attach the factory Y to the manifolds. Just remove the O2 sensors first, so you don't shatter the sensors when banging on those bolts, like I did. Almost forgot, make sure you have a fresh can of Copenhagen. Everything is easier with a big fat dip in your lip <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<small>[ October 09, 2002, 06:42 PM: Message edited by: 11 Bravo ]</small>
Old Oct 9, 2002 | 06:41 PM
bo0oost's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Ballistic Z:
<strong>you do have a ypipe right? Other than that looks like you got the big stuff, better pic up a tube of anti seize for the bolts that hold the headers on. Other than that, i think you've got it all.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yep, got the 3" hooker ypipe to connect to my Mufflex 4" catback.
Old Oct 9, 2002 | 06:53 PM
bo0oost's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 11 Bravo:
<strong>Make sure you have a small 1/4 inch ratchet for the header bolts, especially the dreaded rear passenger bolt. Wear a long sleeve shirt unless you want the coil packs to shread your arm when tackling that bolt. Have something to cut the thin aluminum fuel line sheild. The front drivers O2 sensor won't clear it unless you cut a small piece away. I just cut a small "flap" so it still protects the fuel line. You have the EGR mod, right? Also, it helps to have an air wrench to remove the rusted bolts that attach the factory Y to the manifolds. Just remove the O2 sensors first, so you don't shatter the sensors when banging on those bolts, like I did. Almost forgot, make sure you have a fresh can of Copenhagen. Everything is easier with a big fat dip in your lip <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Do I need to replace the aluminum around the fuel line shield after I cut it?
What EGR mod?
Hehe, thanks!!
