MAFT @ stk MAF or Ported MAF
Thanks
<strong>You guys that are running a MAFT are you running a ported MAF or a stock MAF.I know the ported MAF will give a lean mixture most of the time are you using the MAFT to get the ideal A/F ratio,or are you going stock MAF and leaning out from thier.I would think the ported unit will flow air better and use the MAFT to go richer if needed.
Thanks</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">If you are running a M6 then I would say go ahead and port your MAF and use a MAFT to fine tune, if it's a A4 use the MAFT with the stock MAF! Ported MAF's have been linked to tranny failure in A4's, A ported MAF tricks the computer and causes a loss in line pressure for the A4's. this is what I keep hearing from everyone, maybe someone will know more about the subject of A4's and ported MAF's?
If you have a HPP3 or some kind of tuning device, you can bump up your line pressure to negate the effects of the ported MAF. The same thing is true with a shift kit since it also raises the line pressure.
I personally will use a MAFT in conjunction with a descreened stock MAF. I'm going to pull the screen out today, and when I have time, I will pull out the laptop and try to tune my car with the MAFT.
