TB port/polish help
Old Oct 13, 2002 | 07:00 PM
BensZ28's Avatar
Default TB port/polish help
I just ported and polished my TB with my trusty dremel and put everything back in. I cleaned the TB very well making sure there wasnt a trace of grease or dust left on it. When I put it back in and starter her up, it was idling near 1500??? Turned it off, started it again, idle was just below and felt weird. Is everything ok? I also did the TB stop mod
Old Oct 13, 2002 | 07:38 PM
unit213's Avatar
Administrator
Default Re: TB port/polish help
I could be way off base here, but I would imagine it may take a little bit for the computer to re-learn everything.
BTW, when you did the TB bump stop mod did you shorten the accerator cable? Just checking...
Dan
Old Oct 13, 2002 | 07:54 PM
FstBlkz28's Avatar
hmmm give it a day or two to adjust, if it doesn't go back to normal RPM's at idle, you can try reseting the computer.
Old Oct 13, 2002 | 08:52 PM
slick98ta's Avatar
Hope you didn't open the blade and port in there?Because your not suppose to,and would cause your idle to go sky high if you did.
Old Oct 13, 2002 | 09:01 PM
Jay's Avatar
Jay
reset the pcm and then start it up with a/c and other electrical loads off and let it idle for about 5 minutes. It should relearn the idle. You should not have any idle issues after a mod like that though. As said before - I hope you didn't grind where the butterfly seats.
