grinding down front brake calipers
Old Oct 14, 2002 | 11:27 AM
LSWon't's Avatar
Default grinding down front brake calipers
Does anyone have pics? Is this possible to do with a dremmel? How far down do I grind? Thanks for the help guys.
Old Oct 15, 2002 | 01:21 PM
LSWon't's Avatar
Default Re: grinding down front brake calipers
Can some one help me out? I need to put a wider convo pro for the front before it starts to rain around here. Is this possible to do with a dremmel? How far down do I grind? Thanks again.
Old Oct 15, 2002 | 02:00 PM
SStrokerAce's Avatar
what do you want to grind?
Old Oct 15, 2002 | 02:40 PM
XtraCajunSS's Avatar
IMO, you will need a 4" grinder to take off enough metal to do any good. You will need to have the wheel bolted up and try to spin it by hand. It will leave marks on the caliper where it is hitting. I am using 15X4 CL Warriors with a 2 5/16" BS. I really only had to grind 2 specific areas to make it work. Just take your time and grind a little at a time. I had to bolt/un-bolt my wheels about 5 or 6 times to get it right. It took about an hour a side.
Shane
Old Oct 15, 2002 | 05:41 PM
WILWAXU's Avatar
Why are you grinding the front calipers?
I run 15x3.5 Weld rims without grinding the front... just use 5/16 spacer.
Now.. you will need to grind the rears.. here's a website that will help you there... : Caliper Grind
Moving to Drag Racing section.
