Washer fluid spitting up?
Thanks,
Russ
<small>[ October 15, 2002, 05:53 PM: Message edited by: WILWAXU ]</small>
From corvetteforum.com:
Get Windshield Wiper Fluid Check Valves (1 package = 2 valves) from Ford Motor Co.- #F8CZ-17A614-AA - $4.08 - any dealer will have it. Remove wiper arms (13 mm bolts under the snap off caps, then wiggle and pull), cut the washer ßuid tube under the blade assembly just before it splits to the 2 output nozzles, and install the valve (1 each side) with the check ball pointing towards the pump - i.e. away from the outlets, and press Þt the thing back under the wiper arm prior to re-install. Nasty Ford part is invisible, and hammering the car = dry windshield. No big deal, I was just tired of cleaning up the solvent residue from the stuff. One note from the service manual that was useful: before removing the wiper assemblies, turn the ignition to Òaccessory,Ó turn wipers to slow intermittent, and turn off ignition when they are down (at end of cycle but not parked all the way down on the stops where they go to when you turn them off). Then use a piece of masking tape on windshield on both sides to mark their position so that the reinstall is properly aligned.
