Open Headers... good or bad?
Old Oct 16, 2002 | 05:07 PM
Sears's Avatar
!Dial-up Director
Default Re: Open Headers... good or bad?
You will lose a little low end with open headers and extensions. This graph compares my dyno with open headers vs. dual exhaust.
<img src="http://www.fryrice.com/images/dualdyno.jpg" alt=" - " />
Justin
<small>[ October 16, 2002, 05:09 PM: Message edited by: Jsears8 ]</small>
Old Oct 16, 2002 | 07:53 PM
gator's 99TA's Avatar
does anyone have an open header v. y-pipe dyno chart? also, justin did you change the programing at all when you switched to true duals?
was it worth it to go open header?
Old Oct 16, 2002 | 11:37 PM
Boo Yeah's Avatar
but the question is what were current mods? What cat-back? and also would it make more power with a cutout on the I pipe.
Old Oct 17, 2002 | 12:12 AM
98NBMSS's Avatar
Default Open Headers... good or bad?
Will I gain or lose power if I run open headers? This is kinda tied to the old backpressure question. I have always thought that all backpressure was bad and that "if" I lost low end torque I would make up for it with top end horsepower. Is this true? Thanks in advance.
Luke
Old Oct 17, 2002 | 12:22 AM
Classic's Avatar
From what I've been reading it is ok to run open headers if you have extensions off of the collectors. I believe that if you run directly off the collector you will lose power, but maybe someone else will know a little more about this.
Old Oct 17, 2002 | 09:30 PM
Sears's Avatar
!Dial-up Director
Program stayed the same, air/fuel was pretty much on.
Current mods are Heads/Cam/Bolt ons/12bolt , only thing that was changed was the exhaust.
Justin
Old Oct 18, 2002 | 02:12 PM
justin, do you by chance have a borla v. open header dyno?
