#8 Plug
Old Oct 20, 2002 | 06:02 PM
OfficerZ28's Avatar
Default #8 Plug
Did anybody else have to remove the passenger cat to get to the #8 plug from underneath a 2k1 Z28?
Old Oct 20, 2002 | 07:15 PM
ls1 joe's Avatar
Default Re: #8 Plug
Its easier to remove the coilpack assembly, at which point you will be able to remove the #8 plug.
Old Oct 20, 2002 | 08:06 PM
spdracer's Avatar
Default Re: #8 Plug
i changed the #8 plug form the bpttom of the car, you do not have to remove the cat, just make sure that the car is cool before you do this. i think that it is easier form the bottom since you dont have to remove the coil packs.
dustin
Old Oct 20, 2002 | 08:46 PM
OfficerZ28's Avatar
Default Re: #8 Plug
I tried to remove it with the cat on, but i couldnt get my hand and arm in there...maybe i was taking it from the wrong angle...so i took it off and it was very reachable
Old Oct 20, 2002 | 10:02 PM
rnr27band1's Avatar
Default Re: #8 Plug
hey man what ever works, cat off, coil pack off, or just reaching around. i made my plug change easy by removing the manifolds, and replacig the plugs then putting headers on. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Oct 21, 2002 | 07:08 AM
TA_2001's Avatar
Default Re: #8 Plug
I did # 8 from the bottom with no problems,
Old Oct 22, 2002 | 12:25 AM
numbZ's Avatar
Default Re: #8 Plug
I also did #8 from the bottom using a stubby ext.You can't see what your doing so you need to feel your way around.
