muffler placement
Old Apr 24, 2006 | 07:54 PM
98charlize's Avatar
Default muffler placement
i want to put side exit exhaust on my 98 camaro but don't know what the best place to put the muffler is. i want an x pipe then into chambered stick mufflers. should i put them closer to the exit or closer to the cats? i want to keep some back pressure for low end torgue. thanks for the help.
Old Apr 25, 2006 | 09:04 AM
jmm98LS1's Avatar
1. Put the muffler closer to the exit. I hope you're not lowered, and you're skilled at fabbing up exhaust because clearance is an issue w/these cars. Side exhaust ain't easy.
2. You don't want back pressure....ever....none. Do a 'search' in this section on back pressure. You'll find all the info you want. Needing back pressure in an exhaust is pure myth. It's all about velocity.
Old Apr 26, 2006 | 02:30 AM
98charlize's Avatar
Default side exit
when i open my cut out there is a lose in low end power. will it sound different if its closer the cats or farther away? thanks guys or girls.
Old Apr 29, 2006 | 12:12 AM
98charlize's Avatar
anyone, the help would be great.
