Air Temperature Module
Old Apr 24, 2006 | 09:16 PM
00silverT/AWS6's Avatar
Default Air Temperature Module
Are any of you running this? I saw it on AfterThoughts Auto. they say you gain 5 to 7 hp, which isn't much but every little bit helps, right?
Old Apr 24, 2006 | 09:20 PM
98TADRIVER's Avatar
it advances timing i believe. i used a 4.7Kohm resistor i belive it was, a cheap cheap resistor from radioshack. just plug it into the plug where the IAT sensor used to be tricks the computer into thinking it is 55-57 degrees constantly.some people say that when the outside temp gets too hot, your car might ping from too much timing, but personally i have never had any trouble. you can try it to see what you think of it and always plug your stock sensor back in
Old Apr 25, 2006 | 09:34 PM
lomaximumta's Avatar
that thing sucks. ruined the way my car ran. Shitty piece. Save up for headers.
Old Apr 26, 2006 | 09:35 AM
Rebelord's Avatar
stay away from that thing. wont work worth a damn, especially if your in a area thats gets hot.
Ski
