Switching intakes
Old Apr 25, 2006 | 01:58 PM
brokez's Avatar
Default Switching intakes
Got a freind that's going to let me take his ls6 and he's going to take my ls1.Can't just switch the coolant pipes from his to mine and the ls1 **** to his.Then I would only need to but the intake gaskets right
Old Apr 25, 2006 | 02:35 PM
conan's Avatar
Yes switch the 2 plugs in the back of the heads and the front crossover pipe. Replacing the gaskets is a good idea too.
Old Apr 25, 2006 | 02:41 PM
brokez's Avatar
Then just put all the lines that were under my intake on his side and bolt up the ls1 intake and thats it? Thanks for the help
Old Apr 25, 2006 | 02:47 PM
conan's Avatar
You got it.
Old Apr 25, 2006 | 03:00 PM
brokez's Avatar
OK last question I promise Will his throttle body be any better than mine it's totaled so might as well get all I can
Old Apr 25, 2006 | 04:23 PM
mattsls1's Avatar
tb's should be the same.
Also you will need a tune after switching intakes. When I switched to the ls6 my a/f went from 12.9:1 to 15.0:1
