HOOD BAFFLE HELP PLS
Old Oct 24, 2002 | 04:28 PM
fak005's Avatar
Default HOOD BAFFLE HELP PLS
Team:
I just removed both hood baffles from my car yesterday and I had to drive in little rain today.
I noticed that water had reached the lowe rpart of airbox tray that the filter sits on but not on the filter. Is this normal?
Also, what and how can I make comething to cover the honeycombs incase of rain.
Thanks,
Adnan
Old Oct 24, 2002 | 04:56 PM
BLK02WS6's Avatar
Default Re: HOOD BAFFLE HELP PLS
What I did was tap the two upper holes in the long baffle and when it is going to rain, I stick it back in and have two screws holding it from inside the hood - it works well and is easy. I also made my own transition piece to seal the hood to the box out of heating duct material. It really helps.
If you have an oiled filter (KN type), a little water will not get through.
This reminds me - it is supposed to rain tonight -better go stick the baffle in...
Old Oct 24, 2002 | 06:14 PM
wojan's Avatar
I seriously doubt that it would get past the air filter.
I took mine out over a year ago and not had any probs (in Carrollton - sort of near you).
Wojan
Old Oct 24, 2002 | 08:35 PM
Skizzy's Avatar
i also took both baffeles out of my car about a year and half ago. i have never had any water get to or past my air filter. if you want a good way to seal it up from rain then go to http://luna.snu.edu/~operativex/formulaws6/index2.html and go to where it says modification on the left and click then scroll down to where it says removed hood baffles. it is a friends site.
<small>[ October 24, 2002, 08:37 PM: Message edited by: Skizzy ]</small>
Old Oct 24, 2002 | 10:55 PM
fak005's Avatar
I have removed both baffles in my WS6 hood
do I have to remove the honeycomb in front permamnently or leave it in there?
Thx,
Adnan K
Old Oct 25, 2002 | 07:18 AM
WILWAXU's Avatar
I have run no baffles and a Whisper Ram Air for nearly 2 years now without any troubles, car has been driven about every kind of weather without a single problem.
I remove the honeycomb grills only for the track. Mostly because I don't like the look with them out.
