Octane Help...Please Read!
Old Oct 25, 2002 | 09:10 PM
SSuperSSport's Avatar
Default Octane Help...Please Read!
I have had problems in the w/ pinging...partly due to the octane level of the gas I was using. I have now started using higher octane gas, but 92 is the best I can find w/o driving to another town. My question is, does anyone use an octane booster per gas tank to help w/ the level of octane and prevent pinging. Are they bad for your fuel system?? If so, which one do you use?? Please Advise!
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Thanks,
Jeff
Old Oct 25, 2002 | 10:27 PM
WeatherGuy's Avatar
Default Re: Octane Help...Please Read!
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by SSuperSSport:
<strong>I have had problems in the w/ pinging...partly due to the octane level of the gas I was using. I have now started using higher octane gas, but 92 is the best I can find w/o driving to another town. My question is, does anyone use an octane booster per gas tank to help w/ the level of octane and prevent pinging. Are they bad for your fuel system?? If so, which one do you use?? Please Advise!
Thanks,
Jeff</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You may be getting pinging/detonation because of running too lean - which may have nothing to do with the gas.
Running too lean is a problem that sometimes occurs with the use of a lid and an aftermarket MAG - both of which you have. I used to have severe detonation problems with my old stock block from those mods.
Old Oct 25, 2002 | 11:25 PM
horist's Avatar
Now started using 92 octane? Sorry... reminds me of a guy I know that used to have a TA....
I would suggest not to use octane boosters... unless you like changing plugs and having a red tint on your plugs when you do change them...
If you're car's stock you should have no problem running off of 92 octane... I run 93 octane with that democrat instigated , tree hugger supported, George Ryan corrupted (vote Jim Ryan not BagBoyABitch <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> ), illinois, stupid reformulated gas....
<small>[ October 25, 2002, 11:27 PM: Message edited by: horist ]</small>
Old Oct 26, 2002 | 06:00 AM
Thanks Guys. If I am running too lean...how do I fix it? What are my options?? I definately want to fix before I cause any costly damage!
Thanks,
Jeff
Old Oct 26, 2002 | 09:36 AM
LS1derfull's Avatar
RamChargers MAF translator will allow adjustments, real easy too. 5% increments for base and 2% for WOT settings. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Oct 26, 2002 | 09:58 AM
WJ SOM SS's Avatar
If your car is a '02, try putting the stock MAF back on the car. Think your problem will be gone. WJ. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Oct 26, 2002 | 10:46 AM
JWRENCH's Avatar
I think the maf translator would help you out quite a bit. Also check out your granatelli maf, a lot of people don't know it but they make two for your car. One for a stock airbox/filter, and one for a cold air intake. The one for cold air will have a "c" after the part number.
Old Oct 27, 2002 | 12:26 AM
I don't have my stock MAF anymore. I sold it to a friend, and I bought my GMAF used, so I can't really look up the number. Is there any way to tell by looking at it??
How easy is it to use a MAFT? Is is complicated?
How much does it cost??
<small>[ October 26, 2002, 12:27 PM: Message edited by: SSuperSSport ]</small>
 Michael S. Palmer
Old Oct 27, 2002 | 12:33 AM
WJ SOM SS's Avatar
Believe me, get rid of the Granatelli MAF and put a stock '02 back on. No more problem. WJ. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
