maybe coil?
Old Apr 26, 2006 | 04:27 PM
ssman00's Avatar
Default maybe coil?
heres the deal I drove my car on a mountain cruise it ran fine and had no troubles. I got back and it sat for about a week, then when i got back in it it skips and runs like crap, I am thinking it may be a bad coil. Is there anyway to check the coils individually?
Old Apr 26, 2006 | 04:31 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Well, there probably is, but I doubt that a coil went out like that.
I would start with your fuel system and go from there. Change the filter...ect.
Old Apr 26, 2006 | 04:40 PM
Charlie@LsXperts's Avatar
mine does that every once in a while, i think its the fuel pump.
Old Apr 26, 2006 | 04:43 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Some shops might be able to hook it up to a tester. There are testers for the blaster type coils and for spark plug wires, but I bet that it would be about the same for testing the current.
Old Apr 26, 2006 | 05:27 PM
sickss228's Avatar
Yeah you got to test the resistance on each coil. If you have a multi meter you can do it.
Old Apr 26, 2006 | 06:31 PM
crows_camaro's Avatar
Or The Easy way is to go to Advance Auto and buy a tester. they plug into the end of the wire that would snap on the plug. Crank the car and see if you are getting fire. Total cost of like $7.97
Joey
Old Apr 26, 2006 | 06:55 PM
ssman00's Avatar
thanks for the help guys I dunno if thats what it is for sure but its like its only running on 7 cylinders and it just happened all at once with no warning signs or nothing
